Turbine angle in Comp-ARF Kangaroo
Hey guys,
I have a Kangaroo with a modified engine mount, so i need to figure out the down thrust angle of the turbine, and from the manual, they only tell you to add washers under the rear bolts of the original mount, which i obviously cant, since my mount is significantly different than stock.
anyway, can anyone tell me what is the maximum and minimum down thrust angle of the turbine ? i will be checking my mount with a Robart incidence meter.
Is there a recommended angle by those who flew this plane before ? please bear in mind im not a begginer pilot.
thanks.
