RCU Forums - View Single Post - Spitfire 60 engine offset?
Old 01-27-2007 | 04:49 PM
hambone1
Default RE: Spitfire 60 engine offset?
Here it is balancing. One problem though, they call for the CG @ 90MM. After an extra battery stuffed in the nose(retracts), I have the CG @ 95MM. Will this be ok , or is it absolutely critical to have it at 90?
I would probably just try it if I didnt spend so much time on it....
Thanks guys
