ORIGINAL: lxcoupe
Even though I have less power now the plane seems smoother. With harrier flight before I had some wing rock which could be partly caused by the back and fourth hammering that the YS was doing at idle or just above. The brielli is much smooth down low and it seems to really lock into the harrier now.
Did you ever run the bigger 19" prop on the YS. Sometimes just a step up in prop Dia seems to help a lot for everything. I have a 60" FL330 and going from a 15 to 16 prop makes everthing better.
