RCU Forums - View Single Post - Which Sherwin Williams Auto Clear to Use?
Old 02-05-2003 | 01:26 PM
CobraJet's Avatar
CobraJet
Default Which Sherwin Williams Auto Clear to Use?
Viper,
These are the clears I've used. Mostly the CC635 for airplanes and heli canopies and lately the CC639 (Super clear but a few $$ more). I've had great success laying these clears over the Pactra RC car paint (airbrushed or spray can) as a time and cost saver. I use the SW base coats for the larger projects.
CC635 ULTRA 7000® HS Air Dry Clearcoat
CC637 ULTRA 7000® Maximum Performance Clearcoat
CC639 ULTRA 7000® Super Glamour Clearcoat
Pick you hardener based on your painting environment:
UH22 Ultra System Rapid Hardener
UH33 Ultra System Medium Hardener
UH44 Ultra System Medium-Slow Hardener
UH55 Ultra System Slow Hardener
UH60 ULTRA System Air Dry Hardener
These are self-explanatory and have the temp range on the label:
US1 ULTRASOLV® #1 Cold Temp Reducer
US2 ULTRASOLV® #2 Cool Temp Reducer
US3 ULTRASOLV® #3 Moderate Temp Reducer
US4 ULTRASOLV® #4 Warm Temp Reducer
US5 ULTRASOLV® #5 Hot Temp Reducer
US6 ULTRASOLV® #6 Tropical/Desert Temp Reducer
You can thin out the last coat of clear as much as you like (I've gone over 200%) with no adverse effects in 60-90+ deg temps.
WRT the spot putty, I believe the blue, red, or green will work fine and the auto paint store should carry either one. I use both the green and lately the red spot putty on my current street rod project.
Good Luck!
