RCU Forums - View Single Post - 3MM TOC-53 Gas Engine
Old 01-28-2007 | 10:31 AM
3MM
Default 3MM TOC-53 Gas Engine
TOC-53
Displacement 53cc
Bore 44mm
Stroke 35mm/
RPM Range 1200-7800 RPM
Horsepower 5.5 HP
Weight 1880g all up
Fuel/Ratio Premium Gas mixed 40:1~50:1
Piston Rod 2 Needle Bearings
Crankshaft 3 Ball Bearings(nsk)
Ignition 4.8~6 Volt- Electronic
Prop Size 2 blade 22x8, 22 x 10 ,23x8 3
www.3mmodel.com.tw/
ID:	608285   Click image for larger version
ID:	608286   Click image for larger version
