RCU Forums - View Single Post - Turbine angle in Comp-ARF Kangaroo
Old 01-28-2007 | 12:41 PM
erbroens's Avatar
erbroens
Default RE: Turbine angle in Comp-ARF Kangaroo
My Roo has a lower mount and the turbine is paralel with the wing mounts, and there is not pitch trim change at any speed or throttle setting.
My guesstimate for your particular setup is about 2 degrees of up thrust to minimize the Roo pitch down tendency, or better yet, try to mount the engine lower.. you´ll get a much finer flying machine.
Enrique
