ORIGINAL: preich
I just bought and loaded FSOne on a Dell Precision M20 running Windows XP Professional. Ver 2002 SP2, with a Pentium M processor, 2.13Ghz, 1GB of 787Mhz RAM and an ATI Mobility FireGL V3100 graphics adapter.
FSOne crashes whenever I try to edit a transmitter dumping me back to the desk top or causes a complete shutdown or cold boot.
I've updated the video drivers to the latest version, patched FSOne to V 1.0.4 and back to 1.0.3 with the same results. As I bought the software only version, I have had no sim time yet as I need to configure for my Futaba Xmitter. After about 4 hours of fiddling, All I have is a door stop.
What gives? Not enough hoursepower? Do I have a boat anchor? HELP! [&:]
Ok, does the sim run to the point where you can go to the Main Menu, then to Single Player Freestyle, then select an aircraft (and use the default transmitter), and then click Fly and see the sim load and run fine but you lack control since you're not using the stock TacCon controller? If so, this is a transmitter setup problem, and we can try to help you with that. If it doesn't run at all, it's something else, and we'll try to help you with that.
