RCU Forums - View Single Post - Turbine angle in Comp-ARF Kangaroo
Old 01-28-2007 | 03:57 PM
erbroens's Avatar
erbroens
Default RE: Turbine angle in Comp-ARF Kangaroo
Well, I think it is worth doing it even if that means punching holes or glueing blocks in your great paint job.. first of all you need to saw that single point mount.. then you put the turbine a little aft and lower. Here are two pics of options you can do it. Of course, this is also a refinement that you can add later, tilting the rear of the turbine up like Sap2000 suggested will make you get almost the same results.
Gary.. I done some mods on my Roo even if I was happy the way it flew. by doing this I ended with a much better and capable airplane. In fact, right now I don“t fancy any other available sport jet design, and that was not the case when I was flying the Roo on its standard configuration.
Enrique
ID:	608524   Click image for larger version
