RCU Forums - View Single Post - E-FLITE BLADE CP PRO
Old 01-28-2007 | 04:40 PM
  #1242
Truglodite
Default RE: E-FLITE BLADE CP PRO
ORIGINAL: goplaneman
Does your current tail work alot better than DD, or just easyer to set up and cheeper?
it works better than all the tail setups i've used so far (still want to test gws DD w/ hh though). it's only $1 less than DD since you don't need to buy a DD prop. it's a bit more difficult to setup the geared brushless, mainly because you have to press a pinion on. in my case i also had to bore out the stock pinion (since my order of 3 century high authority pinions didn't arrive early enough for me).
btw, i reprocessed the video to get rid of the dropped frames. it's already uploaded and relinked if you want a better view of those punchouts and whatnot.
