RE: Top Flite 1/7 P-51 Build
Using the Robarts 605 Retracts with 653R and 633L struts. Does anyone know how much you cut off, or did you use them full length? With the 3 1/4 wheels, wanted to get as much ground clearance as practical.
With then angled into the wing, they should end up being about 90 degrees to the ground.
Looks like from some of the pictures, you end up with the wheel fairly tight to the center ribs.
Bruce
