RCU Forums - View Single Post - FS One by Hangar 9
Old 01-28-2007 | 09:04 PM
  #629
MSelig's Avatar
MSelig
Default RE: FS one by Horizon Hobbies
ORIGINAL: preich
ORIGINAL: MSelig
preich -
When you plug your old Fut into the FS One USB Interface, do you see the sliders move inside the Windows Game Controller Gadget (control panel)? This is a test that is completely removed from the FS One app.
Michael
Yes. From Control Panel/Game Controllers, the FSOne interface is listed and with the old Fut plugged in, under properties, I get movement on all 6 channels.
Very good. Your hardware is good.
Let's try this. Start FS One. Go to Options | Messages and click on [] Use Default Options Upon Shutdown. Exit FS One.
This will set everything in the options back to the default install.
When you restart, you should see the Alpha40 airplane. Click on the Tx. Click on one of the Hitec Optic 6 Tx's. Click on Calibrate, and calibrate - move all six controls on your Tx. Click next next next etc until Finish.
Now do six sliders move in the FS One Tx window (the Hitec setup)?
Michael
