RE: Silver soldering
G'day Mate,
Borax is generally used for silver soldering, it is mixed with water, & is a soft paste, available in plumbing supply stores or hardware stores, under silver brazing flux.
You propane torch should be hot enough, for small jobs, just heat the end of the rod, if it melts, your torch is hot enough.
