RCU Forums - View Single Post - Landing in a field?
Old 01-29-2007 | 08:57 AM
rwright142's Avatar
rwright142
Default RE: Landing in a field?
I had almost the same issues when I first started. The grass field I started flying from was rough and the grass was touching the prop. I would cut a lot of grass before finally taking to the air .
I bought a larger nose wheel and that kept the prop from cutting the grass. For the rough area, if you own the land see if you can roll it to get smoother.
