RE: bubbles in fuel lines
did you check the fuel line that are attached to the clunk at the fuel tubing inside the tank?those tubes have very sharp edges and can cause a tear in the fuel line when you slide it onto the tube.checking the tank for leaks externally wont show a fuel line leak inside the tank.
