RE: 9303 Slaving Flap to Aileron
There are a few different possibilities for set up for that. Here is one example. First select INH under gear and aux 2 in device select, and if you only want the slider active in one of the 2 positions and no other switches controlling the flaps, select INH under FLAP as well. Then in wing type select the gear channel on dual aileron and the aux 2 channel for dual flap. Then to set the flaps up as ailerons, set up a program mix, mixing AILE to FROL, assign the mix to the MIX switch, and if you want the mix active in pos 0 set the rates up in the pos 0 values. To set up the slider, set up a mix, mixing LLVR to AUX1, assign the mix to the MIX switch, and set the values in the pos 1 values as desired.
