RCU Forums - View Single Post - Trim Solvent - Acetone...same thing?
Old 02-05-2003 | 04:25 AM
David_Moen
Default Trim Solvent - Acetone...same thing?
Hi all!
Playing around with some Monolote scraps....seems like I can stick 'em together REAL good with acetone. Paint a bit on the glue side of a "trim" piece and lay it down on another and in a few minutes it is stuck down good enough that if I try to peel off the trim bit, the underlying layer pulls off of balsa wood before the covering will come apart. No bubbles between the layere either.
Has anyone tried to use acetone for covering purposes? Any known down sides?
