RCU Forums - View Single Post - Cleaning for epoxy repair?
Old 01-29-2007 | 11:16 AM
Charlie P.'s Avatar
Charlie P.
Default RE: Cleaning for epoxy repair?
Not really hard, but you do want to be thorough. There are products called "Deglossers" and solvent washes specifically to remove wax from fiberglass (The gelcoat/paint is often the first part of a boat that goes in a mold, on top of a layer of mold release wax. This wax has to be removed before adding trim or touch-up paints). Acetone will work, but you have to use lots of rags or you'll just spread the wax around and it will re-harden once the acetone evaporates off.
