RCU Forums - View Single Post - Weight lifting competitions.
Old 02-06-2003 | 04:50 PM
Zweihander
Default Weight lifting competitions.
Thanks for the input.
Main reason for designing a biplane is for maximum lift on a small wingspan. I'm trying to get a 13kg lift out of 183cm wingspan.
From what I have seen conventional gear landings can be difficult with heavy loads.
I am not sure how heavy loads will work with conventional gear, stearing could be difficult on takeoff.
Asthetics are not a problem, as funtionality is 1st priority on this plane.
I'm not even sure where I would mount trike gear on a biplane, very little documentation on it?
