RE: First time builder... Needs advice.
I built the GP Cap 232 40 as my first kit build. It was a blast! Directions were crystal clear, everything fit where it was supposed to. The landing gear plate, however, is woefully inadequate. Although it means adding a little weight, replace the 1 inch landing gear double with at least a 3 inch plate, and put some triangle stock on the sides (you'll see how when you build it). The first time I flew mine, it took off great, but on landing ripped the gear out, even though it was a nice gentle landing. After beefing it up, I can bring it in on the mains, and let the tail settle as it slows down. Real Purty!
Brad
