RCU Forums - View Single Post - .46
Thread: .46
Old 01-29-2007 | 07:22 PM
opjose's Avatar
opjose
Default RE: .46
Well you can but quoting right from the web site...
" *Because the .46LA dimensions are different than a bearinged engine,
it will not work in this plane unless modifications are made. You
will need a different engine mount. Depending on which engine
mount is used, you may need to add aprox. 1/4" to 3/8" plywood
to the firewall to extend the prop forward enough to keep it from
contacting the fuselage.
It will be a slow flyer with the LA... though I've seen several set up this way... and have flown one.
It was too docile for my tastes, but then I like faster planes.
