RCU Forums - View Single Post - Removing monokote
Old 01-29-2007 | 08:03 PM
bruce88123
Default RE: Removing monokote
It sounds like you are trying to assemble an ARF or a covered kit. If you are just trying to remove an area so you can install the elevator carefully use a soldering iron to cut the coveing at an appropriate point. Once you get it started you can lift the covering slightly from the wood and cut with a new blade. Be sure you do not cut the wood. After removing the desired section, re-iron the remaining covering.
Question - do you need to remove the covering from both the top and bottom of the elevator? In many planes you do.
