RCU Forums - View Single Post - moving the firewall back on a CG Ultimate..?
Old 02-05-2003 | 08:34 AM
punkey71
Default moving the firewall back on a CG Ultimate..?
Hi Guys,
I'm building a CG ultimate. It's only my second kit (first was a 4* - wow what a difference) and i'm being challenged to say the least. I'm using a Saito 150 and need to move the firewall back a 1/2" in order to keep the thrust washer in the correct spot per plans. So......How the heck to I do that?!?!?!?
I would think it would be fairly easy if the fuse was a perfect square....just lop off 1/2" of the front of all sides. The problem is the fuse bottom actually comes up as it goes forward (not a perfect square).
_____________________
<----front
\ ________________
Ok...that's the worlds worst attempt at a diagram, but I think you get the point!
My inexperience is probably showing here and I bet dollars to donuts there is an easy answer...unfortunately, I have no idea what that answer is!
Any help would be greatly appreciated.
Thanks in advance,
Harold
