Time for the Leqding Edge
OK, the glue on the center joint is dry and we are ready to continue onto facing the leading edge. Remove the weights and tape and get the LE strips.
We use Titebond Wood Glue and plenty of masking tape. Nothing difficult here. Simply bevel the root side of the two LE pieces for a perfect center joint and ensure they run straight down the leading edge of the sheeted cores. Masking tape every 10cm will keep everything straight and ensure a perfect bond. It will take about two hours for the alphatic resin to dry.
