RE: Zeque Build Glow Powered...
Regarding reliability of various control linkage combinations...
I have reviewed a number of photographs and made a few phone calls. I incorrectly stated that..."I have used the MK 2.5mm rod adjusters using the Central Hobbies 2.5mm titanium ends...". I was mistaken. I actually used the NMP dual axis ends (DARE25 $5.98, Central Hobbies)) on the servo ends for the ailerons and the elevator used the NMP 3mm dual axis ends. The NMP dual axis ends provide both rotational and linear action from one part. I also called Al Coomber of Central Hobbies to discuss further and he suggested that although a tight fit, the 3mm threaded pushrod ends are better for the MK 2.5mm rod adjusters or to simply use the 2mm MK rod adjuster as was recommended by the recent contributor from California.
Once again, I appreciate the feedback!
Rusty Dose
Team Futaba
Team YS Performance
