And here it is installed.
I could not think of anything else that needed to be photographed here. A little epoxy/microballoon mixture and the post is inserted flush with the rear edge of the fin. A small notch at the bottom of the post is made to key it to the tail wheel block.
The most important part here is that the fin is clamped flat to the post. Our clamping blocks are very straight pieces of high density particle board that are longer than the fin post. The Burna clamps provide nice gentle, but firm pressure.
This will sit for twenty four hours now. In the mean time we will start elevators and the rudders, keep sanding more tips, and get to the ailerons too.
