RCU Forums - View Single Post - ZNLine factory: Enigma Building
Old 02-20-2003 | 08:05 PM
  #123
MarkNovack's Avatar
MarkNovack
Default Then I sanded.
First, I very carefully fed the elevators through the band saw to cut away the excess. The stabs would not fit under the band saw feeder guide, so I sanded it down to about 2mm or 3mm on the belt sander. Same with the rudder.
After cutting them down I started in with the razor plane and then finished by hand with my big sanding block.
The tips I shall round down tomorrow when I am feeling refreshed.
Here is the root view.
