Originally posted by MarkNovack
As far as the delay on this thread, I am still sanding tails. It takes me about 4-6 hours to get one stab set and rudder sanded to where the coverer will accept it.
Mark
Mark, could you kindly share your surface prep technique ? Do you fill every single wood grain boundary ? Do you sand wet or dry and what grit sizes do you use ? Any special jigs used here ? What type of filler do you use for wood and composites? Thanks again...........
