RE: hows this?
In addition to the heat sinc cooling it looks like you could get a couple of turns of some water cooling coil near the brushes which is where the heat comes from. Thats a tough one. I would run it and see how hot it gets with the cooling you had on it. If it gets too hot you might want to consider changing the motor mount.
