ORIGINAL: Taylor Shaw
ORIGINAL: Gyrotech
No.it doesn't matter. air cooling does a better job then water cooling any day !
Thats quite the statement!
I'm not going to try to prove you wrong but I see alot of the serious computer guys going to watercooling for overclocking needs.
different then a motor.
a motor heat come from the core. the core is the armature of the motor and when you attach water cooling to it, it cools the out side can and the magnets. So the only heat transfer from the hot "spot"armature is the 2 bearings and 2 brushes. there for air cooling that blows rite through the motor and out the other side would be much more effective.
Most of the heat comes from where the brushes touch the commutator. not the armature.
