RCU Forums - View Single Post - Tricks to removing M26 track return roller?
Old 01-31-2007 | 09:05 AM
shenlonco's Avatar
shenlonco
Default RE: Tricks to removing M26 small idler?
Hey Rich try this it should work use a dremel motor tool and first go around the stuck road wheel with some electrical tape then use some sort of big round bit in your dremel and put tape around it also..then on low RPM press it up against the road wheel so it spins it add some presser do this for a few seconds and it my losen up from spinning it so much with the dremel.
