RCU Forums - View Single Post - phoenix decathlon
Old 01-31-2007 | 11:50 AM
  #76
RCVFR
My Feedback: (7)
Default RE: phoenix decathlon
You have your engine mounted a little low. The horizontal mark on the firewall should be where your engine center lines up. It looks like you are about 6mm low from that. The engine center is lined up with the bottom of the engine mounting lugs, and that is where you want the alignment with the firewall to be. I'm sure your engine install will have no flight effect, just cosmetic.
