RCU Forums - View Single Post - Setting idle speed with tachometer
Old 01-31-2007 | 07:03 PM
Flying freak
Default RE: Setting idle speed with tachometer
ORIGINAL: fadi81
For Idle:
I set my engine in such a way to pick up instantaneously when transiting to full throttle; and for this I need to let in the correct amount of fuel/air mixture that will be burnt completely at idle without leaving any accumulated fuel in the piston head. I am not afread of lean mixtures, bcs at idle the engine fins are able to cool it properly without any extra help
When I set the idle, let's say at 2500rpm on my OS 46AX MAX, I then "clean" it by doing some full throttle revs, and then drop it back to idle and watch the speed with a tacho.
If the engine idle is set accurately, the tachometer should read 2500rpm all the time with minimal variations, and you can idle forever until the tank is empty. What you will often notice is that as you idle, the rpm tends to drop when the needle is not set correctly and it eventually dies!
Ok i am not very experince but how can our model engines idle all tank long..I mean the oil will accumulat after some time and end up pooling there and the rpm will drop.. are you saying we shoudl adjust to the point were we are burning ALL the oil as nothing will accumulat...
