Do I hit the swash cover on the main shaft while flying?... Well.. Flipping her over, doing TicToc's, Hurricanes, etc...
J/K. No, just noticing it when checking travel of the servos. I've also installed the hs-55's and adjusted the swash linkage so it just Barely... Barely.. could touch the main rotor shaft at extremes. I haven't checked, but I bet I threw the default pitch off on the main blades doing so too.. lol. Still flies fine, might just lift off a little sooner. Idle Up seems to have the same negative pitch as before.
