Engine Troubles. Help desperately needed!
Note... don't just replace the front bearing. replace both front and rear bearings at the same time. the probability is that the rear bearing had fragments of the front bearing get in it... And both have the same number of hours of use, and the same amount of lubrication has been available to both. The rear, generally being a larger dia will typically not be AS loose... but its still worn, and would be likely to fail rather shortly anyway.
