RCU Forums - View Single Post - Sanding expert
Old 02-01-2007 | 10:30 AM
Quinoa
Default Sanding expert
As I have read, sanding is the most boring task, but really important.
Which sanding tools have the modellers? Are you a sanding expert?
Can you then explain to us what´s the best way to sand? Using sanding blocks? Sanders?
How do you prepair your own sanding blocks? What kind of sandpaper do you usually use for the different parts?
