RE: Maxair Revolution II Velox
I got the mighty 110 delivered today! hopefully the Velox will come tomorrow. the manual for the ys says not to use 4 stroke fuel because of the low oil content. I guess as long as it has 22% oil it's ok? anyway it says not to adjust the regulator screw, and the hsn should start at 1 1/2 turns open. also it shows fuel filters on both pressure line and carb line. do you guys use filters on both? And one last thing, they recommend prop sizes 13.5/10-13 and 14/10-12. I guess that would be for pattern flying instead of 3-d? I got the 16-4 and 16-6. If I need to order a couple more and some fuel filters I can.
