Fun-bat
Denny,
I have a funbat with an mvvs15 on it. It is quite a handfull if you slow it down too much. As long as it is under power it flies great, but the moment the fan quits the fun begins. Make sure you put epoxy around the motor mount inside the wing, the vibration tends to work the motor mount loose.
