RCU Forums - View Single Post - Servo advice for a trainer
Old 02-01-2007 | 10:31 PM
bruce88123
Default RE: Servo advice for a trainer
ORIGINAL: uetigers
yes, I have a new J-3-10 cub I can't determin if the servo should be flush or stick out the manual looks to show it being almost flush the servo tray has two blocks one on each end but the manual points to the servo try and not the blocks. the servo that they suggest to use is MH-48 (jsp20040) what do I need to do thank you
Can you at least give us the mfg of the plane or a link to the manual? Not much to go on here unless you want guesses. The more you give us, the better.
