Bad New Engine `Need HELP!!
This is normal for a OS40LA series of engine.
The crank end play is from a bushing crankshaft. Without the drive washer, you are seeing the clearance between the crank pin and the rear cover.
All ABC engines are tight at the top of the stroke when new.
Jim
