RCU Forums - View Single Post - Bad New Engine `Need HELP!!
Old 02-07-2003 | 10:54 PM
Whirley Bird
Default Bad New Engine `Need HELP!!
Originally posted by sport10
off after using about a gallon or two of fuel with castor in it. The only thing that the air leak affects is the engine turning off. Thats all. Avoid idle bar glowplugs with this engine they mess up the throttle transition. OS A3, OS #8, and Tower Power Plug work best. Good luck.
Sport10
.I'm not sure if I understand.
I was told that a different gasket was needed.
If you have a leak I assume that it will get worse with age?
I appreciate the info but i'd rather run my engine with no air leaks.
Wouldn't it be better to just correct the problem?
1-2 gallons of fuel is a lot.
I have 6 of each plug you listed.
Thanks for the post
