RE: Making control surfaces?
We used to cut stiff paper, very stiff paper, and tape it to the control surface we were testing. It worked like gangbusters for the tests. It worked for 125mph CL combat stabilators on models pulling 10X the g's RC airplanes pull.
That'd be for initial tests. And I'd suggest you do some testing first. It takes more than larger surfaces to change the personality of most models.
