RE: Dual elevator halves uneven. Setup help needed.
So im to understand that when the ele is in the nuteral position the front edge isn't on the same plain as the hor.stab its higher or lower,right?
Then the hinge line isn't centered. simple problem,it will fly that way without much of a problem but if you feel unsafe with it that way just cut the problem ele.half off and redo it. you can use a hinge guide to mark the correct location. not much of a problem to fix.
