RE: How much torque is needed for a throttle servo?
The bigger problem is how long it will last with the vibration that it gets through the throttle pushrod. I use HS 81's for the throttle and they are fine, the 55 doesn't have a good way to rubber mount it and the gears are so tiny, vibration will wear out the servo pretty soon.
