RE: Matt Chapman cap 580 .40 size
HI
How are you guys doing. Just out of curiousity has anybody that is running a Saito engine mounted sideways noticed that you have to use a throttle "cable" instead of the supplied pushrod. This is due to the throttle arm location on the firewall.
Also are you guys using digital ball bearing servos or just standard stuff.
Thanks Scott
