RCU Forums - View Single Post - Ts Oxalys build
Old 02-03-2007 | 01:02 PM
Rune
Default RE: Ts Oxalys build
done some more !
the carbone canopy is ready , my carbon cloth was a bit bad ..so some places it carbon was a bit open had to use a thin glass cote insed the canopy to get it sealed , i also used a bit more clear paint than i needed .
This made it maybe 5-10 gr heavier than it had to be , but that is ok!
this is the way it was done http://home.online.no/~ofremmi/HowTo..._and_epoxy.htm
On the cocpit job I save 61 gr on the cocpit floor and 32 on the cocpit total 93 gr , not bad!
the cocpit are not to be glued on yet it makes the acces to tha fuse during building a lot easyer so tha will be almost the last thing .
As I fly on a grass field i decided to make some reinforce on the UC mounting plate as well 2 tiny in front and one that run from one side to the other in the back this also stiffen up the front end off the wing sadel(english word??)
all the wing mounts are glued in ,used epoxy and microballons .
ID:	612790   Click image for larger version
ID:	612791   Click image for larger version
