RCU Forums - View Single Post - Wing Mfg B25 Build
Old 02-03-2007 | 02:03 PM
Fili's Avatar
Fili
Default RE: Wing Mfg B25 Build
ChuckI, I used the 3M sytrofoam adhesive. I simple sprayed both surfaces, waited a few seconds and put the two sides together. I then applied weight and then let sit for a while. I found the Dave Browns Southern Sorgham works much better (sorry 3M) and would recomend using that instead of the spray. I just feel better about the bond.
Meanwhile, apart from rebuilding the top of the tail sections, progress is slow, but sure.
