RE: Aspect Ratio
nothing to do with the airfoil. It is the ratio of span to mean chord
span * mean chord = area
aspect ratio = span / chord
span^2 / area
higher aspect ratio means less induced drag and reduced downwash = greater pitch stability, smaller tail required
greater lift per degree AoA (lift slope) = a little more sensitive to changes in AoA ( wind gusts, for example )
