RE: What Problames Should I Expect???
If you have ever cut or drilled into metal before, you will know that there is little bits that stick out the sides. You then have to file them off. The same thing happens with the clutch shoes, but if you dont remove them then the rub the clutch bell and cause it to over heat.
