RCU Forums - View Single Post - Engine 4-stroking?
Old 02-04-2007 | 09:23 PM
downunder's Avatar
downunder
Default RE: Engine 4-stroking?
Tune it in the order Kweasal said and if it still sounds like it's 4 stroking at idle but has instant transition when you gas it then don't worry. Car engines will run 4 stroking rich at full throttle if you set the main needle that way just the same as plane engines but you can't clean up the idle mix by adjusting the high speed needle.
