Originally posted by klenker
Its bad enough having the Propane around, but its a very small quantity and dissipates into the air very quickly. Gasoline when spilled is much more volatile and hangs around as an ignition source for DAYS.
Bob
I'm in a pedantic mood.
I do believe that spilled gasoline would not be an ignition source. It would be an accelerant. Something else (a match, a cigarette butt, a wet starting turbine, a hot chick walking by) would be the ignition source.
Be that as it may, you are quite right. Spilled gasoline and model turbines are not a good mix.
...jim
